01 ds650 quit running out of nowhere
Old Dec 12, 2009 | 07:48 PM
murder's Avatar
Default 01 ds650 quit running out of nowhere
a couple days ago i was out at a gravel pit not rippin but just puttin in and i went up the hill didnt romp on it or anything and as soon as i got to the top and started to go back down again it shut off.
i checked the gas and on off switch.. it has spark and fuel i did a compression test and it read zero..
cam chain snap?
it turns over fine. i dont hear clunking.
oh and it will backfire every once in awhile
but it was odd it went right up the hill no problem and then died
Old Dec 12, 2009 | 11:20 PM
stunner4206's Avatar
chek ur batterie and ur cdi ur batt is probably low that makes it sputter and ur cdi is probably not working properly
Old Dec 14, 2009 | 01:12 PM
cucuy's Avatar
No compression! broken chain or rings!!!
Backfire on this is either low voltage or out of timing
Old Dec 14, 2009 | 04:32 PM
murder's Avatar
okay battery is good i did a load test.
i will add this.. when i ride doubles (i know ur not supposed to) but when the rear shock would compress it would sound like my valves were stressing or my chain was 'whipping' like bouncing but from the header area. i thought it was a loose header spring.
i wanted to ask and make sure/ try to pin point the problem area before ripping it apart
TegraQuad
1) Engine problems..
13
Nov 26, 2017 01:40 PM
chinkapin
Jul 14, 2016 06:58 AM
tycobb
ATC 3-Wheelers
Oct 23, 2015 07:37 PM
NLWarrior01
Jun 28, 2015 12:54 PM
sticky123
Jun 14, 2015 07:36 AM
