Need help troubleshooting 2003 400 4x4
Old Dec 18, 2009 | 08:02 AM
deerslayer01's Avatar
Default Need help troubleshooting 2003 400 4x4
I have a '03 400 Auto FIS 4x4 that is having an issue when it gets warm. It will start fine and run fine for about 15-20 minutes and then it will practically shut down. It will still idle, I can shut it off and it will start right back, but it will not come off of idle. It sounds like it is missing and will not go above idle. I thought the first time it happened that I had fouled a plug but that wasn't the problem. I can shut it off for 5-10 minutes and it will start back up and run maybe 1-2 minutes before it does the same thing. I have replaced the air filter and spark plug. I also have a new battery in it.
I am thinking that maybe the coil is going bad and the heat from the engine is messing with it since it is mounted right above the engine.
Anybody seen this before?? The forecast is for 8-18" inches of snow so I really need it running correctly or I am going to have to be very patient pushing snow.
Old Dec 18, 2009 | 09:23 AM
davethegunman's Avatar
Could be coil, maybe even CDI.
Could you have water in the fuel?
Old Dec 18, 2009 | 09:50 AM
TLC's Avatar
TLC
I would think coil the they do that when there going out,not so much CDI .
Old Dec 19, 2009 | 07:26 PM
I was thinking the coil but now I am thinking it might be that stator. A local independent mechanic said he has seen the symptons from several '02 and '03 cats. Might have to get him to check it out since I have no idea what to look for.
Old Dec 20, 2009 | 01:48 PM
david nunn's Avatar
Default starting and running problems 2003 400 artric cat
hard to start and will not stay running. changed fuel and spark plug , any help
pgamboa
Dec 24, 2023 11:52 AM
ReconBayou
Oct 16, 2019 02:24 AM
EIF
Apr 20, 2017 07:15 PM
Impalaman
1) Engine problems..
12
Nov 8, 2015 07:17 AM
Hw00d
Sep 10, 2015 08:53 AM
