ds650 fcr 39mm carb problems need help
Old Dec 18, 2009 | 08:00 PM
ds650r's Avatar
Default ds650 fcr 39mm carb problems need help
just bought a 2002 bomb ds650. it has the full rotax exhaust, dual 39mm fcr carbs and uni pod filters. it will start but wont stay running or rev up. what size jets should i run? how many turns on the mixture screws?
or any other info will help
thanxs
Old Dec 20, 2009 | 12:50 PM
TheStir's Avatar
Started riding ATVs in 1974!
Have you talked to the old owner? Did it sit for a while before you got it? If it was running good for him you may just need to do a good carb cleaning. That is where I would start.
Old Dec 20, 2009 | 03:21 PM
ds650r's Avatar
Default carbs
carbs are clean. i put in fresh gas and new plugs and still the same but after lookin closer i think the headgasket blown. i think coolnt was sprayin out of the header so i drained the oil and it had white milky stuff in it so i think it needs a headgasket.
Ty Speece
Jul 2, 2015 04:59 PM
generalpops
Jun 5, 2015 08:23 PM
garyt1975
Jun 5, 2015 08:53 AM
generalpops
Jun 3, 2015 08:25 PM
kevbowe
Jun 1, 2015 01:17 AM
