95 trail boss starting issue.
Hello,
And Happy 2010
I have a been given a 95 trail boss so the history is not available. I started the basic clean up and tune up on the quad. I power washed the frame ,changed the oil ,..... I installed a new battery and nothing. No lights,no start ,dead. I took the battery and had it tested then installed in sportsman started great. What is the most common issue these bikes have when it comes to the electrical.
I already checked the grounds
cleaned the started solenoid
checked the neutral safety switch on tranny
I'm stumped is there any direction I should go
any advice would be so helpful.
Thank you
And Happy 2010
Thank you
Thank you for the response, I have checked the fuse and cleaned all the battery connections ,cleaned all ground connections, In removing the cowling's I found that a red wire coming for the key switch had been frayed and damaged. I just cleaned the electrical terminal block but cant find the spade it belongs to. Dose anyone have an electric schematic I can look at???
I,m almost there, Thanks
Remember the smaller the rooster the louder the crow !!
what fuse need you check because Im haveing the same problems you are and I can not find any fuse, I have a 1995 brail boss, And I was rideing it and it just stop and I cant get it to start. I have spark,gas etc. It just turn and turns over. I even spryed either in the carb and still nothing.
