95 trail boss starting issue.
Old Jan 1, 2010 | 02:22 PM
lionsfn's Avatar
Default 95 trail boss starting issue.
Hello,
And Happy 2010
I have a been given a 95 trail boss so the history is not available. I started the basic clean up and tune up on the quad. I power washed the frame ,changed the oil ,..... I installed a new battery and nothing. No lights,no start ,dead. I took the battery and had it tested then installed in sportsman started great. What is the most common issue these bikes have when it comes to the electrical.
I already checked the grounds
cleaned the started solenoid
checked the neutral safety switch on tranny
I'm stumped is there any direction I should go
any advice would be so helpful.
Thank you
Old Jan 1, 2010 | 04:09 PM
ftwflh's Avatar
Check the circuit breaker
Old Jan 1, 2010 | 06:48 PM
lionsfn's Avatar
Thank you for the response, I have checked the fuse and cleaned all the battery connections ,cleaned all ground connections, In removing the cowling's I found that a red wire coming for the key switch had been frayed and damaged. I just cleaned the electrical terminal block but cant find the spade it belongs to. Dose anyone have an electric schematic I can look at???
I,m almost there, Thanks
Remember the smaller the rooster the louder the crow !!
Old Jul 4, 2010 | 04:37 PM
slater25's Avatar
what fuse need you check because Im haveing the same problems you are and I can not find any fuse, I have a 1995 brail boss, And I was rideing it and it just stop and I cant get it to start. I have spark,gas etc. It just turn and turns over. I even spryed either in the carb and still nothing.
slater25's Avatar
did
wildbill59
Jun 20, 2015 02:26 PM
1000gade
May 27, 2015 12:37 PM
PolarisPower500
May 17, 2015 02:28 PM
EXtreme
Sep 10, 1999 12:54 PM
Matt24
Aug 3, 1999 07:46 PM
