Replacing chain rub block
Old Jan 5, 2010 | 03:37 PM
Sandman2.0's Avatar
Default Replacing chain rub block
Just wondering if anyone has replaced the plastic chain rub block on the Swing Arm. I have an 03 330 trailboss and just replaced the drive chain. I noticed the wear block is rubbed about 1/2 way through. I figured it would be a piece of cake to replace until I realized its riveted in instead of screws. Polaris engineers really go out of their way to make service a real PIA on these things. I don't think I could get a drill in there without a right angle adapter. I'm seriously considering waiting until the block wear more. I think the chain was run to loose by the previous owner.
Old Jan 5, 2010 | 03:42 PM
scootergptx's Avatar
Supersock
Hired Gun!
I had mine torn off on my trail boss, replaced it (used) and had it happen again. I don't have it on there anymore. I know it serves a purpose, but I was beginning to believe that purpose was for me to keep buying them.
Old Jan 5, 2010 | 04:32 PM
Kerbbirds's Avatar
will wear the swing-arm out instead of the block, as long as you keep the chain adjusted properly the block should last awhile longer.
Old Jan 6, 2010 | 07:46 PM
4getful2's Avatar
just wait till you need swing arm bushings ,then replace it
Old Jan 7, 2010 | 06:57 AM
Sandman2.0's Avatar
That sounds like a good idea. I think once I adjust the chain tension it will be barely touching it as stated in above post. It still has 1/2 its life left so I should be good.
ghost civic
Jul 20, 2015 12:36 PM
trouttracker
Jul 20, 2015 11:54 AM
95wolv
Jul 17, 2015 08:13 PM
joeyupton
Jul 14, 2015 11:51 AM
Unzzy66
Jul 11, 2015 10:01 PM
