Ignition Switch Connection Harness
Old Jan 5, 2010 | 05:49 PM
manum's Avatar
Default Ignition Switch Connection Harness
I am looking for harness end that clips into the ignition switch on my 2005 Magnum 330. I have a short in the connection and instead of redoing the entire harness, I thought I would splice one in instead of replacing the entire harness below the handlebars.
Thanks
Old Jan 6, 2010 | 06:32 PM
Thanks
There are a couple sections in Parts Unlimited,Tucker Rocky,and K&L catalogs that have various electrical connectors,BUT I havent seen the one for the key switch. This a hard to find one (at least I havent found one ) You can purchase the connector pin tool with an assortment of pins and redo your connector. The harness your talking about is the complete wiring harness as it includes the switch connector. We have a couple old harnesses from wreck/totaled jobs that we keep for this same purpose if a machine comes in from rat damage,theft,etc. You can check some salvage yards if any around your area. OPT
Old Jan 6, 2010 | 08:30 PM
manum's Avatar
Hey-great suggestion. Where would I find the pin tool. I've been searching for the scrap option with no luck. That is what I was hoping for. I understand the harness is $$$$$.
Thanks
Old Jan 6, 2010 | 08:49 PM
[QUOTE=manum;2882288]Hey-great suggestion. Where would I find the pin tool. I've been searching for the scrap option with no luck. That is what I was hoping for. I understand the harness is $$$$$.
Thanks[/
The harness is over $200 and a time consuming job for just one connector! The best tools are on the tool trucks,Snap-on,Mac,Cornwell,and Matco. My mechanic(rather my replacement) has a set,but dont know the cost,SHOULD be a lot cheaper than a harness kit OPT
skinnyr6
Aug 25, 2023 02:18 AM
jeepwheelin02
1) Engine problems..
Jul 18, 2020 06:42 PM
Ripinandtearin
Dec 11, 2017 08:06 PM
WILLLANE8302
Aug 7, 2015 08:24 AM
Ripinandtearin
Jul 19, 2015 08:38 PM
