Loncin 150cc wont run with cold weather .
Old Jan 10, 2010 | 12:50 PM
tjuker's Avatar
Default Loncin 150cc wont run with cold weather .
Its winter in here and it doesnt seem to do good for my quad, it's quite hard to start it when its below 0C but some starting fluid will do the trick . After i get the engine going, i can only ride about 2-3km and then it just bogs down and wont react to throttle, after a minute or two sitting, itll start up and i can take it for a little spin before it happens again , one day i can drive it without any problems but the other day, it just bogs down. It seems like the carb freezes up but it feels warm when touched . Got the carb cleaned and adjusted,cleaned the air filter and changed the spark plug . I forgot to check the oil level and i drove around pretty much without any oil in the engine, filled it today and the engine ran smoother but couldve this damage the bearings and once the engine gets hot jam them ? Anyone had a similar problem ? Ps. the cylinder is pretty much done, itll get a new cylinder kit soon but i dont think it has something to do with my problem atm .
Old Jan 10, 2010 | 02:22 PM
OneTenCC's Avatar
You must have had some oil in there or the engine would have cratered. Drain it again and see what's in the oil (just don't forget to fill it back up). Will it run if you feather the choke? I'm guessing you've got a jetting issue with the carb. Another cleaning might be in order.
Joel
Old Jan 10, 2010 | 05:58 PM
LynnEdwards's Avatar
Electrical Expert
Sounds like you're running out of fuel. If the fuel line or filter is mostly plugged up, and the carburetor uses fuel faster than it can trickle in from the tank, then you will eventually stall and have to wait for the float bowl to slowly fill back up. Then the cycle repeats.
Pull off the fuel line going into the carburetor and see that the fuel will flow out freely.
My 150cc quad did this when it was brand new. My symptoms were *exactly* the same as yours. In my case I had a defective fuel shutoff valve that was plugged up with extra plastic from the molding process when it was made. I drilled it out - it has been fine since.
Old Jan 11, 2010 | 09:10 AM
tjuker's Avatar
Yeah, the fuel could actually be the problem, will check it out when i have time . Thanks !
Old Feb 16, 2010 | 07:26 PM
BSpray29's Avatar
TJuker,
Check the fuel tank cap vent. If it is not venting properly it could cause the problem you are describing.
ultangler
Nov 30, 2024 01:35 AM
dannytas
Sep 26, 2017 06:31 PM
LemonTea
2) Chassis problems..
Oct 2, 2015 03:50 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
