850 xp spark plugs
Old Jan 13, 2010 | 05:47 PM
gaspumpcity's Avatar
Default 850 xp spark plugs
I have done a search for part numbers I only saw Highlifters post about the 09 xp with a 6043 number not the 2010 Im wanting to go to the auto parts store not polaris any help here also any special tool?
Old Jan 14, 2010 | 07:27 PM
deerwagon's Avatar
NGK Laser Irridium #6043 (ILZKAR7A10). I had a couple places tell me this plug doesn't exist, trust me - I'm holding the box in my hand. I think I got mine from sparkplugs.com - You may want to see if the local store will order them for you, may be cheaper shipping. They work great so far - but, I still let it warm up before thinking about touching the throttle...Jeff
Extreme Long Life Laser Iridium Plug, 12mm Thread, 26.5mm (1.04") Reach, 9/16" (14.3mm) Hex Size, Gasket Seat, Resistor, Extended Projected Tip, Solid Terminal, Extended Projection, Wide Gap, Iridium Tipped Fine Wire Center Electrode and Platinum Tipped Ground Electrode, .040" (1.016mm) Gap, Heat Range 7
Old Jan 14, 2010 | 07:45 PM
FunRide's Avatar
Polaris dealer gave me the following: NGK BKR6E
Old Jan 14, 2010 | 08:04 PM
deerwagon's Avatar
From what I understand: Polaris did a recall/change in the Champion Plugs from a temperature rating of (6) "REA6MC" to a heat rating of (8) "REA8MCX". The main reason for the fouling is not letting the machine warm up prior to touching the gas which plays havik on the plugs; thus the higher heat rating. That's why I like the one's I have because it's a better plug and a temp rating of (7). They are made for a 6.2 liter Mercedes Benz and the NGK rep himself did all the research based on specs to find this plug for my buddy. Maybe they came out with something else, but the temp rating on the one's you listed are a (6) and changed by Polaris to an (8).
These are for the 09' 850XP, not sure about 2010' changes.
#6043
Old Jan 14, 2010 | 08:19 PM
FunRide's Avatar
Originally Posted by deerwagon
......These are for the 09' 850XP, not sure about 2010' changes.
Interesting. I'll have to ask the dealer. My 850 in an '09 too. I've never had a hint of fouling and I blip the throttle like you said, no re-flash either.
Old Jan 14, 2010 | 08:24 PM
deerwagon's Avatar
Trust me - eventually it will just roll over. When I pulled the plugs they didn't even look that bad. They said the problem was that the salesmen at the dealer's like to start up the machines and rev the throttle right away to show off the "throaty rumble" of the 850 engine - they do this as the machines computer is trying to calibrate the fuel injection/RPM's and it directly effects the plugs. Before mine went I was doing a lot of firing it up and moving it here and there while cleaning the garage or unloading from the trailer etc.
I did buy some of the new Champion plugs for back up on the trail $3 each compared to $12 each.
Old Jan 15, 2010 | 04:31 PM
FunRide's Avatar
Deer....You are correct. I called my dealer back (parts guy) and asked that he double check the spark plugs he gave me based on what you're saying here. Sure enough, it's the wrong part according to Polaris. They now list the "REA8MCX" as the correct plug for an '09 XP 850.
Why is it that one has to double-check pretty much every part one orders? Seems the odds of getting it right these days are low. Great for the shipping companies though. Same goes for a lot of businesses.
Old Jan 16, 2010 | 08:48 AM
HIGHOCTANE's Avatar
The 850's plug is an oddball, the only plugs made that are specified for it are the Chamion plugs.
The NGK ILZKAR7A10 is not technically spec'd for the 850 because it's heat range is slightly different,it is actually designed specifically for one vehicle,the Mercedes E63 AMG...just so happens the demensions are the same as the 850 plugs,which again are an oddball size in the US,a little more common in Europe.
The ILZKAR7A10 can be found readily online,but it is harder to find local. I'm not even sure it shows up in NGKs US catalog,I oringinally found it in the European catalog.
There is also an NGK Platinum plug with the same demensions that will work...I think I posted that part number in another thread here a while ago.
Bottom line is if you want a plug other that the Champion or the NGK I listed then be ready to do some reasearch....there are probably others out there that will work..but someone will need to dig them up by their specs.
Old Oct 15, 2019 | 05:07 PM
Flyboy66's Avatar
#6043
do you have a reference to that change my dealers don’t know anything about it.
Big bousse
Sep 26, 2015 10:42 AM
cornermike
Jul 30, 2015 06:37 AM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
Dirtbikemike1
Jul 21, 2015 04:13 AM
