OMW DS730/815 Cylinder & Piston Kit w/Extra's
Up for sale is our "like new" 105.5mm DS800, long skirt cylinder & piston kit + extra's.
Designed by OMW - manufactured by Calvin Pollet.
This cylinder has just returned from Millenium with a fresh Nikasil coating that has not been run on.
Gasket mating surfaces are blemish free and true to within .001
The cylinder can be used with a stock stroke crank (730cc) up to +10mm (815cc).
Special care has been taken to achieve a piston/cylinder clearance that optimises leakdown 96%,(with proper sealing valves) - yet allows for the use of at least 40hp worth of nitrous. Can take more but that is as far as I got.
The piston is brand new and of the latest design from OMW - High Performance + Nitrous use. Lightweight & VERY durable.
Approximately 13:1 compression ratio with stock stroke crank & a standard head gasket thickness.
The ring package (also new) that is used with this piston is of the highest quality and significantly improved over the standard 105.5 ring set. With a low oil ring set tension, an improved parasitic drag co-efficeint is realized. This ring set will survive nearly forever on motor and several seasons on the bottle.
I am also including several used (but usable) 105.5mm MLS head gaskets in various configurations to suit your compression.
New base gasket.
Coolant line attachment included.
Also included is a used standard performance piston & rings (in O.K. condition) AND a used high performance piston (in great condition) both of which were run in this cylinder.
This piston/cylinder kit are the very ones that we used to achieve an average 300' e.t. of 3.90 with a 215# pilot, with a best of 3.87 in a +8mm stroke configuration.
Purchase these products with the knowledge that you are getting a superior product with the expert technical support of Eric Oldham (Mr. Horsepower) of OMW.
The original retail price of the base cylinder & piston kit from OMW is $1500.00 + $200.00 for the higher performance piston & rings.
We are offering this package with all the extra's for $800.00 + shipping. Add 3% with the use of Paypal.
Give your DS the kick in the pants that you know it needs & you want !
New base gasket.
exmotocrosser
Sep 13, 2019 06:12 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
