Replacing Coolant Hoses
Old Jan 15, 2010 | 09:52 PM
ctdnwakulla's Avatar
Default Replacing Coolant Hoses
I am in the first stages of work on a 97 Scrambler 400 and am very new to the ATV world in general. I have been wondering about the coolant hoses. I would like to replace all the hoses with something,besides the dealer, that would withstand the elements. I looks like 3/4 heater hose. Is this correct? And are there any surprises using a good hose in bulk,ie; one end smaller than the other? Last, What kind of hose would you suggest?
Thanks Bill
Old Jan 16, 2010 | 06:57 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
what ever hose you use, make sure it's the correct hose to hold up and make sure they don't rub on parts to cause holes. imo
Old Jan 16, 2010 | 07:10 AM
700 sportsman's Avatar
Silicone hoses will be extremely durable, but they will be pretty expensive.
Old Jan 16, 2010 | 02:03 PM
4getful2's Avatar
whatever hose you use ,don't forget new clamps
Old Jan 24, 2010 | 11:35 PM
Well after researching my hose options I opted for Gates Green Stripe 3/4" and 7/8" heater hose. This hose is hard to find by the ft, but located it at a heavy duty truck parts house. I purchased 6' of 3/4 and 6" of 7/8 for just under $20 including tax. IMO, this is the way to go, if you want a heavy duty hose, but don't want the expense of silicon. I have pics, hope they turn out.
Attached Thumbnails Replacing Coolant Hoses-srambler-009.jpg   Replacing Coolant Hoses-srambler-010.jpg   Replacing Coolant Hoses-srambler-012.jpg
Old Jan 25, 2010 | 08:28 PM
looks like it'll work good as long as you don't have any tight bends that would have to be pre-bent in the hose
Old Jan 25, 2010 | 09:16 PM
ftwflh's Avatar
I have a used set in good shape that have the bends and everything.PM if interestesed
Old Jan 25, 2010 | 11:10 PM
I checked the fexibility of the hose prior to purchasing. It is suprisingly fexibile for the wall thickness. There were no problems on the installation, no kinks at all. I did use the stock spring and heat shield, but felt this may not even be needed. Just look at the difference in the wall thickness over stock, it may be over kill, but I like over kill at this cost. They also make a bendable spring cover that can help on some of those tighter bends. I hope this may help someone in the future, so far I have been very pleased.
SDR-II
Sep 29, 2015 01:06 AM
toonces
Jul 28, 2015 01:58 PM
WilliamBos
Jul 25, 2015 02:41 PM
ghost civic
Jul 20, 2015 12:36 PM
Coryco
Jul 6, 2015 07:30 PM
