Bicycle speedo?
Old Feb 26, 2001 | 02:13 AM
txtrailboss's Avatar
Anybody using a bicycle speedometer on their ATV? if so, what kind and how/where did you mount all the parts?
Thanks
Old Feb 26, 2001 | 08:05 PM
Rammer's Avatar
I have a Bell 8-function speedo on my '01 400 Xplorer. I mounted the sensor to a flat bracket that I mounted to an existing treaded hole in the caliper mounting bracket. The magnet supplied with the speedo needed to be 1/32" away from the sensor. I took the magnet out of my pick up tool(would trip sensor at 1") and glued it to the rotor. Just watch where you put the magnet, so it doesn't hit anything as it passes the caliper and brake pads. I have around 150 miles since doing this and have ridding in snow, mud ect. without any problems.
Old Feb 26, 2001 | 11:20 PM
You are talking on one of the front wheels, right? How big was the magnet and what kind of glue did you use?
Thanks for the help!
Old Feb 27, 2001 | 05:18 PM
Rammer's Avatar
Yes,I mounted it on the right front. I used an industrial glue that is similar to super glue. The magnet itself helps hold itself on also. The magnet I used is about 3/8" in diameter and about 1/4" thick. I got the magnet out of a telescoping pick up tool, that can be bought rather cheaply. I also had to add wire to the harness,as it was not long enough to mount the speedo to the bars.
Old Feb 27, 2001 | 09:51 PM
leel's Avatar
I mounted mine on the front axle on the universal joint yoke (99 Scrambler 400). The front axle spins all of the time, the 4wd just enages the hubs also. Remember, it doesn't matter what size the shaft is that you use to mount the magnet if it's spinning the same speed as the wheel would if engaged.
Good luck,
Lorrin Lee
Old Feb 27, 2001 | 11:10 PM
Thanks for the help! I put mine on tonight, and it works like a charm.
speedbuff
13
Nov 11, 2020 10:16 AM
01ssls1
3) General Discussions..
Sep 21, 2015 12:23 PM
black_thunder
Sep 20, 2015 10:21 PM
Adrian Turner
Aug 30, 2015 04:08 PM
