Differential oil
Old Jan 23, 2010 | 10:49 PM
polaris man with issues's Avatar
Arrow Differential oil
Can i put 80w90 synthetic gear case oil in the front gear case of my 05 Polaris sportsman 500 ho or do i have to use the over priced Polaris stuff ?
Old Jan 24, 2010 | 03:39 AM
TOO thick for for proper awd operation. I can only recommend Polaris demand drive hub fluid,but other members may have an equivalent they have been using. OPT
Old Jan 24, 2010 | 07:01 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
if theres one place for oil you DO NOT want to cheap out in the front end or hubs as the polaris oil is designed to be used for the awd to work as he mentioned.
Old Jan 24, 2010 | 07:36 AM
switzomatic's Avatar
It's worth it for the popo oil. I change mine twice a year and it still isn't that much. Will help down the road with the dealer if you have machine issues because they will know you maintained it with the proper fluids and stuff.
Old Jan 24, 2010 | 11:05 AM
can i put allison synthetic transmission oil in the front differential? I already put it in the rear transmission and its been in for about 500 miles and its ben good./?? Also hydrilic oil wont work will it? Cause i was looking at the msds sheets and the popo oil isthinner then hydrulic fluid?? Thanks, Polaris Man With Isues
Old Jan 24, 2010 | 11:10 AM
DCT's Avatar
DCT
Banned
Jeeezzzzzzzzzzz... do yourself a favor and use the Polaris Demand Drive fluid... and change it out a lot more frequently than once every 1500 miles for crying out loud. It's not that expensive!!!!!!
If you want to know what's expensive, call a Polaris dealer and ask him how much a new front differential costs. Then for more of a shock, ask him what it would cost to have him replace it. You'll find the prices anywhere from $900 to $1200.
Old Jan 24, 2010 | 03:22 PM
thanks and yeah true the differentials are not the spot ya wana skimp on lubercation the front diffs are really expensive so im gunna go get polaris stuff from my dealer for like $8.00 so how much do ya need and how often should you change it??
Old Jan 24, 2010 | 04:24 PM
DCT's Avatar
DCT
Banned
The manual for your machine says 5 ounces, and to change it yearly. I did mine twice a year.
Make sure you drive it until it is warmed up good.
Park it on a level area.
Let it drain completely.
Put 5 ounces of the Demand Drive Fluid in it. Don't overfill, and don't put in to little. The Hillard diff is finicky when it comes to having just the right amount of fluid.
Old Jan 25, 2010 | 04:40 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
i always use the manual as a guide on how often you should change it and don't have any iisues. as mentioned don't overfill.
Old Jan 25, 2010 | 10:31 AM
TLC's Avatar
TLC
On a 2005 I think the front diff is the Hilliary awd system's location. So the fluid is very specific.
scrounga
Honda Side by Sides
Mar 7, 2016 04:17 AM
Dan Newberry
Aug 30, 2015 09:42 AM
Ferhat Durakovic
Aug 26, 2015 07:04 AM
pro94lt
Aug 20, 2015 10:02 AM
