Moose Hydro turn kit install
Old Jan 25, 2010 | 05:59 AM
noooooo's Avatar
Default Moose Hydro turn kit install
Just finished up the Moose hydraulic turn kit install. My pushtubes are 5 years old and the two brackets that bolt to the pushtubes were about 3/16" too narrow. The pushtubes are not bent because they are consistantly the same width the entire length. I contacted Cambridge metal who makes it and they told me there was no one else who had issues. Nor did they have a solution other than grind it down. You will then be trying to drill holes that are 1/2 a hole off. I eventually cut them and welded them back at the right width. There are not instructions on how to lift the blade. The U bolt that is used originally to lift the blade will no longer fit. I guess I will eventually bend it narrower to fit different holes. Just passing along the info if anyone is interested
Old Jan 25, 2010 | 07:52 AM
vikingman's Avatar
Default Moose hydro turn
Got mine installed also no problem with mount. I installed the winch ubolt thru the second hole in the hydro bracket. Have you used yours yet? Waiting for snow here
Old Jan 25, 2010 | 03:08 PM
noooooo's Avatar
How old are your pushtubes? I am guessing there is a manufacturing variance that ocurred at some point in the past. No snow yet. It all melted so nothing to even try it out on. Possibly some Thursday.
Old Jan 25, 2010 | 04:02 PM
vikingman's Avatar
My tubes are two years old
Old Jan 25, 2010 | 05:27 PM
700 sportsman's Avatar
Could you post a link to your kit, and some pics. if possible?
Old Jan 25, 2010 | 05:56 PM
noooooo's Avatar
I dont know how to link. The websites are fuse-powersports.com and the moose utility division website. They are not cheap but if it holds up it will way more than pay for itself with the light commercial work I do. I will try and post pics late this week. Hopefully Vikingman can post some pics also. I am curious to see how he set his up. There is a short video at the fuse site.
Old Jan 25, 2010 | 06:25 PM
Holy cow! I was thinking 3-400, but it does look like a solid setup, and I see what you mean especially if you do light commercial work
Here's the link for others: Moose Utility Division - Product Catalog
TheHood
Aug 8, 2015 05:49 PM
ghost civic
Jul 19, 2015 10:13 AM
ghost civic
Jul 15, 2015 10:48 PM
rcappie4
Jul 10, 2015 04:54 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
