water or acid
Old Jan 27, 2010 | 08:26 AM
itsfit's Avatar
Default water or acid
my battery has one cell very low, one emtpy what should I put in it before I charge it?
Old Jan 27, 2010 | 08:28 AM
scootergptx's Avatar
Supersock
Hired Gun!
If you have the acid, that's what I would use. If not, make sure you use distilled water.
Old Jan 27, 2010 | 08:35 AM
itsfit's Avatar
Thanks A/P store for acid? What kind do I get? This is the kicker have you ever heard of deionized water? We use it to basicly pressure wash electronics.
Old Jan 27, 2010 | 08:50 AM
lovmudd's Avatar
I would only add distilled water. IMO Even though it looks dry, you will find it won't take much to bring it back up. You might want to keep an eye on it as to why it went dry on you. Cracked, overcharged???? Be prepared to be spending some money for a new one soon.
No fun being stranded someplace with a dead battery.
Old Jan 27, 2010 | 08:59 AM
bitterfitter's Avatar
DO NOT USED DEIONIZED WATER!!! It will kill that battery in short order!
Old Jan 27, 2010 | 09:00 AM
itsfit's Avatar
LOL I know the case shows no cracks what could happen if you over fill it?
Old Jan 27, 2010 | 09:43 AM
DELUX500EFI's Avatar
BUY AMERICAN!
according to Interstate batterys you should only add distilled water and never add more acid...
lovmudd's Avatar
Hard to say, it depends on how much you have overfilled it. Some batteries have somewhat transparent cases with low and high level marks on them. (Getting to be a thing of the past) If you have overfilled it just a little over the high line , I wouldn't worry about it. If you filled it up to the top of the hole then I would make sure your overflow tube is correctly routed as it will most likely be spilling out of that tube as your ride gets banged around.
To prevent that I guess I would try to get some of it out, to bring it back to a safe level.
Remember you are messing with hydrachloric acid (once your distilled water gets mixed into the cells) so be carefull.
Old Jan 27, 2010 | 11:22 AM
Umm, I think it's sulphuric acid.
Old Jan 27, 2010 | 11:58 AM
lovmudd's Avatar
Your right, my bad. I think I was thinking about the Hydrogen Gas during both the charging and discharge cycles.
I should know better than to think!!!!
