water or acid
Old Jan 27, 2010 | 12:51 PM
itsfit's Avatar
Interstate battery store is going to get a visit this weekend their batteries are not that much less that 60 bucks if I need a new one they even have a sealed one for 80 something!
Old Jan 27, 2010 | 05:22 PM
muddynoodle's Avatar
regarding water type, I spent 11yrs in bottled water industry both deionized and distilled are the same total disolved solids but if in dought distilled best choice! if it helps
Old Feb 4, 2010 | 01:57 AM
wilddonkey's Avatar
You can use plain old water. Worked at Interstate batteries for 7 years and we charged thousands of batteries that we topped off with water from the garden hose. If the cell is half empty or more then I would use acid but if thats the case your battery is probably going bad anyway.
Old Feb 4, 2010 | 04:10 AM
aaronrkelly's Avatar
Every battery manufacturer Ive ever read info from said use water only.
Why, not sure.
Ive got a 5 gallon container of battery acid - not even sure where the hell I got it.....so despite the recommendation I use the acid.
So far no ill effects.
I HAD a battery with a date code of 1998 in my KZ1000.....every 6 months I would have to pull it out and top off a few cells, I believe this was mostly caused by my battery tender as well as the battery being worn out. Despite this I would load test it and it would test OK....so back in it went.
Finally this month it test bad....very bad - it had a good run, I finally replaced it.....it didnt owe me anything.
Customer Service #1
May 15, 2020 08:46 AM
Alex G.
Sep 11, 2017 11:38 PM
panicmanic
Sep 28, 2015 12:59 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
