polaris xplorer 300?'s
Old Feb 19, 2010 | 01:10 PM
sly22guy's Avatar
Question polaris xplorer 300?'s
I bought a 1998 polaris xplorer 300 4x4, to use around the property to pull a mower and plow the drives and other odd jobs.
The pull start works fine. and the lights power up when you rev it. i bought a new battery which makes the lights work, but when i hit the starter button nothing, no click no nothing.
Does anyone have a wiring diagram? i figure ill start by checking out the selenoid. but i see they have the wiring spread out all over this thing. id rather not just start throwing parts at it if there is any tests i should be doing to help eliminate and start narrowing down the problem.
Seems that it is either a relay or wiring related. also the battery is not getting charged back up from it running either.
Old Feb 19, 2010 | 05:27 PM
ftwflh's Avatar
THe starter solenoid is by the battery.Jump thet posts and if it starts there is your problem.If nothing replace the starter
Old Feb 19, 2010 | 07:20 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
make the key is in the on position when you jump the 2 big cables on the solenoid like he mentioned.
Ramman1
Aug 11, 2022 01:53 PM
NoJoke
Aug 9, 2015 12:39 PM
Polaris Side by Sides
Jul 30, 2015 12:14 PM
cornermike
Jul 30, 2015 06:37 AM
cornermike
Jul 8, 2015 11:44 PM
