06 grizz 660 wont shift
Old Feb 21, 2010 | 06:56 PM
NWbigmudd's Avatar
Default 06 grizz 660 wont shift
I just got a great deal on a grizz it had a broken axle so i wasent able to get a good test drive in so while I wait on the new axle I went threw the atv and changed every fluid ,drained and cleaned the gas tank,and all looks well. So while still on jakes I started it and tried to see if I could get it to shift and it would not shift up to second. Ive never had an automatic not sure what might be the deal.what can I check or should I just wait until the axle comes and try it on the road. This atv is a 2006 grizzly 660
Old Feb 21, 2010 | 07:10 PM
TexasRoadlawyer's Avatar
No Ruts, No Glory
uhh...thair iz kno secund geeer...idz a bellt-dryve audomadic
Old Feb 21, 2010 | 07:15 PM
NWbigmudd's Avatar
so when in high gear it does not shift up trew a set of rears its just one gear? cuz my duramax has a allison transmision and its an automatic and it shifts, it has 6 gears
Old Feb 21, 2010 | 10:57 PM
Malachi's Avatar
No it will be 1 long continuos gear. Low gear will be the same but geared differently, so it will have less top speed.
The clutch housing on the right hand side has your clutch sheaves. These will control the "gearing" as you increase/decrease throttle.
95wolv
Sep 27, 2024 12:00 PM
Clint Russell
Sep 25, 2015 03:20 PM
BigCam
Sep 16, 2015 01:53 AM
patrick.oc123
Sep 15, 2015 02:45 PM
toonces
Sep 5, 2015 01:14 PM
