87 warrior 350 UH OH......
Old Feb 22, 2010 | 11:12 AM
87 warrior's Avatar
Default 87 warrior 350 UH OH......
i have a loud valve tap and was wondering if i threw a valve??? i've adjusted the valves countless times and that has done nothing. it's been tapping since i got it but not as bad as it is now. I've been meaning to rebuild the top end but never had the time to do it. any help would be great. thx
ps it got worse when i put it in reverse and pinned it lol which i know was a bad idea lol
Old Feb 22, 2010 | 10:51 PM
KNOWSALOT's Avatar
The Facility
What does your valve adjuster bolt look like?? They are soft on those Yamaha 350/400 engines and it could be that your bolt just needs replaced. I see it all the time.
And have you verified the noise is indeed the valve and not the timing chain? Those are a weak link on those engines as well when they start showing there age.
Old Feb 25, 2010 | 06:51 PM
87 warrior's Avatar
it's a 1/4 inch stud with a 10mm nut. it's not the timing chain cause i just replaced it a few months ago. and it's still nice and snug. i was just going to rebuild the whole top end from valves to piston (the works). but if i am going to do that is there a kit that comes with everything or do i have to buy everything seprate?
Old Feb 25, 2010 | 09:12 PM
91Warrior357's Avatar
if i were you and rebuilt the top end i would go with JE 366 piston kit and kibblewhite vavles, D.I.D. timing chain, webb springs and cam if you want.
Reactant
Mar 30, 2022 02:08 AM
STLyamwar
Jul 25, 2020 04:44 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
01ssls1
Sep 22, 2015 06:50 AM
