07 500 EFI Top end
Old Mar 7, 2010 | 03:50 PM
Beefcake35's Avatar
Default 07 500 EFI Top end
Hi- I have a 07 500 EFI sportsman that is burning some oil. I have also lost some performance on it. So- I am gonna start with new piston and rings. What do you recommend? Should I go with oem replacement or do you have aftermarket you have had good results with. Also, I would like to get more performance out of this machine. Does it make that much of a difference boring it .10 or .20 over?
Thanks a bunch!!!
Old Mar 7, 2010 | 04:30 PM
TLC's Avatar
TLC
How much to you want to spend.
Aaen Performance - Polaris ATV 500
Old Mar 7, 2010 | 04:31 PM
Beefcake35's Avatar
I dont want to spend a ton. Really want to just get it back to not using any oil and maybe boost the performance a bit.
Old Mar 8, 2010 | 07:46 AM
Kerbbirds's Avatar
Wiseco makes a piston that will raise copmpression from 10.4to1 to11to1 makes a diff, first you need to tear it down and have cylinder miced to see how much it needs bored, then buy the correct size piston and have it bored to it, I would buy the Wiseco.
Old Mar 8, 2010 | 10:30 AM
Beefcake35's Avatar
Great thanks!
Old Mar 9, 2010 | 12:08 PM
Beefcake35's Avatar
what are your thoughts to just a new set of rings? This quad only has 1400 miles on it. Not sure why its already smoking and burning oil. Would I be ok with just a set of rings or should I do the piston also?
Old Mar 9, 2010 | 12:57 PM
TLC's Avatar
TLC
If the piston is good why change it, I still do not get the rings being bad after only 1400 miles. There are 500s running around with 9000 miles on them.
Like mention a new piston can raise your Compession ratio.
The most common reason for the 500 to prematurely wear out is the person does not use Full synthetic 0w-40 oil because he has a wack of 10w-30 lying around his garage.
Old Mar 9, 2010 | 01:05 PM
Beefcake35's Avatar
I agree. I dont understand how the rings would be bad. I am a amateur mechanic but all signs lead to rings to me.
1. Engine smokes (especially when first started up)
2. Uses oil. (quite a bit)
3. No noticable leaks
4. loss of performance (not as much response when I punch it)
If you have any other ideas what it could be I would love to hear them.
Thanks!!
