Flipping tie rod ends?
Old Mar 1, 2010 | 05:05 PM
8675309's Avatar
Default Flipping tie rod ends?
Question to the guys that have flipped the tie rod ends to gain clearance for wider tires, do you notice the difference in any way?
Old Mar 1, 2010 | 05:30 PM
JCDEYO25's Avatar
I haven't done it personally but from what I've read different guys have had different results...Some worked out great then I've heard of others that had slight "binding" problems...I think it has to do with slightly different ride height due to after market springs or spacers but not 100% sure...
John
Old Mar 1, 2010 | 06:11 PM
I put the HD springs on my 2006 Sportsman X2. I had the dealership try to flip my tie rod ends but he said that it was causing the steering to bind. I ended up getting 3/8" longer 3/8x24 wheel studs pressed in my front hubs #186 POLARIS EXTENDED WHEEL STUDS +3/8x24 -Grade 8 : eBay Motors (item 120537912070 end time Mar-08-10 15:39:31 PST) I then screwed a hardened 3/8x24 nut on each stud, added a hardened 3/8 washer and then the wheel with another washer and hardened nut on the outside. I was able to fit 9" wide ITP Mudlite XTRs on with about 3/8" clearance or so.
Old Mar 2, 2010 | 04:34 PM
Off_Road_Ram_01's Avatar
Flipped mine last spring after adding new tires. No problems to date (yet - lol).
Old Mar 2, 2010 | 05:03 PM
jeffc's Avatar
I put 10" Zillas on the front of my 05 and did not have to flip the tie rod. The Zillas on ITP Black Delta wheels though. The backspacing puts them out another inch, I believe. The right front wheel clears by about 1/8, but the left side is only about 1/16 from the boot on the tie rod and occassionally it will very gently rub the boot. I put the homemade spring spacers on it already and have HD springs on order that should arrive this week. I'm hoping to get that tire just a little bit further out while I have the chance.
You might want to look into getting a different set of wheels to avoid swapping the tie rod?
Old Mar 3, 2010 | 05:43 AM
8675309's Avatar
Thanks for the input. I ended up flipping mine the other night and re-adjusted the toe, works good so far, but still need to do some tweeking on the toe alignment.
Old Mar 9, 2010 | 01:35 PM
blackwaters's Avatar
I just flipped mine no problem what so ever. Zillas 27x9x12 Front and 27x11x12 Rear.
mywifesquad
8
Sep 21, 2015 08:20 AM
black_thunder
Sep 20, 2015 10:21 PM
jsmit116
Sep 18, 2015 10:34 PM
awer1968
Sep 8, 2015 11:02 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
