03 Sportsman 500 stuck in awd
I got a 03 sportman 500 that is stuck in awd I picked it up from a "buddy" I got it this way I tried replacing the switch at the throttle and still nothing any help would be helpful thanks
ATV Time :: View topic - Polaris Demand Drive Hub Q&A Picture Guide to Service
Read this link if your 03 is the hub type AWD.
Is it govenoring is reverse??? Put it in reverse and and give it some throttle ... not sure what speed it should gov. at, but if it doesn't then your override switch is probably stuck on. There is a spring inside the override switch that can come out of place and cause the switch to stay engaged.
It does stop at a certain speed in reverse then I hit the button and it goes faster with the plug connected I will try it with out and see what happens I broke down and bought the repair manual see some of the people I talked to said they think it is a wire touching
micheleLeigh
Technical and How-To Articles
Jul 19, 2015 07:32 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
