03 Sportsman 500 stuck in awd
Old Mar 8, 2010 | 04:33 PM
pv4022's Avatar
Default 03 Sportsman 500 stuck in awd
I got a 03 sportman 500 that is stuck in awd I picked it up from a "buddy" I got it this way I tried replacing the switch at the throttle and still nothing any help would be helpful thanks
Old Mar 8, 2010 | 06:40 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
wonder if the amature plates in the hubs are messing up and staying magintised not letting it go out of awd. imo
Old Mar 8, 2010 | 07:26 PM
TLC's Avatar
TLC
ATV Time :: View topic - Polaris Demand Drive Hub Q&A Picture Guide to Service
Read this link if your 03 is the hub type AWD.
Old Mar 9, 2010 | 03:44 PM
pv4022's Avatar
Thanks for the help
Old Mar 12, 2010 | 06:10 PM
pv4022's Avatar
replaced them and no go still stuck in awd
Old Mar 13, 2010 | 04:59 PM
pv4022's Avatar
Ok I know it is electrical but not sure where to start I pulled the 2pt connections apart and no longer in awd but when I replug it is still in awd and help out there
Old Mar 15, 2010 | 10:35 PM
darrylfifield's Avatar
Is it govenoring is reverse??? Put it in reverse and and give it some throttle ... not sure what speed it should gov. at, but if it doesn't then your override switch is probably stuck on. There is a spring inside the override switch that can come out of place and cause the switch to stay engaged.
Old Mar 16, 2010 | 04:37 PM
pv4022's Avatar
It does stop at a certain speed in reverse then I hit the button and it goes faster with the plug connected I will try it with out and see what happens I broke down and bought the repair manual see some of the people I talked to said they think it is a wire touching
Divergent12
Dec 30, 2017 08:33 PM
Polaris5
Aug 29, 2015 09:11 PM
1000gade
Aug 9, 2015 03:34 PM
micheleLeigh
Technical and How-To Articles
Jul 19, 2015 07:32 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
