850XP too wide after wheel install, suggestions?
I have installed ITP SS112 wheels and ITP TerraCross R/T tires. My problem is that the quad is too wide now for our trails in Wisconsin & Michigan as well as for my own personal preferences with the rear at 5+3 offset.
I see that ITP makes a different offset for the RZR. If I changed over to the SS112 offset 3+5 (part number 1428315404B* for the RZR 4/156) would they stick out less? My second option is to run the SS112 fronts on all 4 wheels (part # 1428313404B) If I go that way what is the largest tire that will fit on that wheel?
3rd option is to go back to stock but I prefer not too. Any suggestions and or ideas? See pictures below. First is with the rear 5+3 offset and the other two are the fronts mounted on the one side.
Thanks
Thanks
Well I hate to say this but I don't think I would worry about it. I have never seen anyone checking for width in Northern Wisconsin or Upper Michigan. Most of the trails are very wide or they are logging roads. I think I would run with them and then worry about if I got stopped. I know this may not be cool with some, but as my big brother says, "Don't worry about it, just pay the fine." IMO
I hear you on the gate thing, that would be bad news. Speaking of gates, I don't know if I have ever seen any here in Wisconsin or the U.P. Most of the areas I ride at are logging roads or smowmobile trails with no gates, due to, I would guess, the width of the groomers. Has anyone seen any gates in this area?
Thor, the 3+5 wheel is even wider.
It's simply best just to stick with the stock wheels for now, unless you plan on lifting it.
Jul 21, 2015 03:03 PM
