srambler 400 rear break
Old Mar 14, 2010 | 07:38 PM
ilocano's Avatar
Default srambler 400 rear break
I'm new to this forum. I need help with rear breaks ,i cant get any pressure on foot pump. It has been sitting for 2 years . I tried bleeding it icant get any pressure. I taken it apart cleaned it and put back together new oil still does not work. There is no leaks, oil comes out of bleed screwin spurts not a stedy flow.
Old Mar 14, 2010 | 07:55 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
welcome to the forum. the polaris rear brakes are not very good and alot of them do loose the pressure as you see. if bleeding doesn't work and you know thers no air in the system, sometimes laying a heavy object on the brake pedal overnight helps build up pressure back up. it's worth a try, but don't guarantee it. imo
Old Mar 14, 2010 | 11:03 PM
ctdnwakulla's Avatar
The foot brake on my Sport 400 is adjustable via a screw, that looks like it holds the pivot arm onto the caliper. Check to see if it works w/hand lever. If it does, the hydraulic system is working. The foot brake on mine is mechanical,not hydraulic. turn screw clockwise to tighten up,then back off till you have about 3/4" play in pedal. ??? I think 3/4 is about right. That is where mine is set. Hope this helps you out.
Old Mar 15, 2010 | 04:58 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
not sure what year his scrambler was, so if it has the mech. instead of hyd. systems sorry for the incorrect information.
STLyamwar
Jul 25, 2020 04:44 AM
greg74
Sep 10, 2019 03:03 PM
slowgsxr97
Sep 8, 2015 04:37 AM
Findlay Tulloch
Aug 25, 2015 05:00 PM
clsharky
Jul 13, 2015 02:07 PM
