More ground clearance
Old Mar 15, 2010 | 07:43 PM
EPD141's Avatar
Default More ground clearance
I have a 2005 Raptor 350. Looking at putting bigger tires on it to gain ground clearance. I'm guessing I'd have to put on a different sprocket. Has anyone had any luck doing this?
Old Mar 15, 2010 | 10:04 PM
91Warrior357's Avatar
if you use bigger tires its gonna make you gear ratio higher, making it accelerate slower, plus the tire most likely being heavier wont help either, but yes if you were to go from say a 20 inch to a 22 it would be a good idea to maybe drop a tooth or 2 on the front sprocket to maintain your gear ratio.
Old Mar 15, 2010 | 10:13 PM
beastlywarrior228's Avatar
22 is about as high as you'd want to go, with the stock 13 tooth front sproket would be perfect. maybe you should look into a good skid plate
Old Mar 16, 2010 | 07:07 AM
Koopa's Avatar
Is addicted to 4 wheel'n!
If you go with 22" I would for sure drop a tooth on the front sprocket. I had a 400EX that had 22" tires. It was a much appreciated change when I dropped a tooth in front. Much less stalling and petering out at the top of hills.
Old Mar 16, 2010 | 09:53 AM
you have to remember warriors have a low gearing from the factory
Old Mar 16, 2010 | 09:58 AM
Koopa's Avatar
And low power. I see what your saying though. Might be able to get away with it. Throw the 22s on and try it out. Can always change the sprocket later.
Joe454
Nov 20, 2020 01:19 PM
EIF
Apr 20, 2017 07:15 PM
salixair
Nov 3, 2015 08:25 AM
Sw00p
Sep 24, 2015 02:50 PM
95scramblerruben1033
Sep 23, 2015 06:29 PM
