polaris sportsman 400 flywheel replacement
Old Mar 15, 2010 | 08:05 PM
nick keener's Avatar
Default polaris sportsman 400 flywheel replacement
i need help replacing a flywheel on my polaris. i am looking for a diagram or the easiest way to do it. please help me out with this.
Old Mar 15, 2010 | 08:15 PM
keiser blade's Avatar
i dont have a diagram, but i took off the right foot guard, removed the pull start cover, then took an impact to the flywheel nut, and to get it off i used a steering wheel puller and an impact
just how i did it, sorry no diagram
later brandon
Old Mar 16, 2010 | 01:56 PM
bcdudley's Avatar
Mine was stuck on real good. The puller would not work for me. I had to purchase a slide hammer kit from harbor freight. It cost about $50. Inside it, there is a small black adapter that is made for putting the fingers on with three channels for each finger. I just stuck the bolts through each of those channels and started pounding for about 20 minutes.
Lots of penetrating oil helps as well. Also, get you a good size brass hammer and give it a good wallop to get some harmonics going inside it to shake it loose.
Good luck.
neilbedwell
Nov 10, 2018 11:02 AM
bikedad3
Jun 29, 2015 08:58 AM
yellowpolaris
Jun 21, 2015 11:13 AM
DOAinNY
Jun 11, 2015 10:34 PM
May 27, 2015 11:15 AM
