2001 Kodiak tires and wheels
Old Mar 24, 2010 | 06:54 PM
alakodiak's Avatar
Default 2001 Kodiak tires and wheels
I just purchased a set of "take-offs"(wheels and tires) and had to have the rears mounted on the old wheels because the "take-offs" came off a IRS machine and mine is straight axle. I left the fronts on the new wheels. When I put the fronts on with the new wheels they seem to stick further out than the stock wheels - will this hurt anything?
Old Mar 25, 2010 | 10:48 AM
sdride's Avatar
It will not hurt anything the new wheels you put on had a greater offset. most Kodiak owners actually prefer the wider stance. Usually they will do it in the front and rear. The only downfall that you may notice is the quad will be a little harder to steer but will be more stable on off camber surfaces
Is this a 4x4 or 2wd?
Old Mar 25, 2010 | 01:59 PM
alakodiak's Avatar
4x4 - Just worried since the back are not as wide it would cause a problem.
Old Mar 25, 2010 | 02:01 PM
sdride's Avatar
as long as they are the correct diameter you will not have an issue.
RedRancher
Oct 15, 2020 01:45 PM
rcappie4
Jul 18, 2015 07:51 AM
Desimation2k8
Jul 17, 2015 12:37 AM
maxjung
Jul 14, 2015 03:10 AM
RedRancher
Jul 10, 2015 06:36 PM
