Kids Quads & Other ATV's - Ask an Expert! An area where experts in their field will answer non-general questions about your Chinese made ATV. mywifesquad, LT80, LynnEdwards and other experts will answer your questions as they have time.
ds 50 wont run??
Old Mar 30, 2010 | 03:59 PM
jday53's Avatar
Default ds 50 wont run??
Hi all. I have a 05 ds 50 it has spark gas and 70-75 lbs compression??? but it will not fire any ideas thanks o yeah thats with a new jug piston rings and gaskets
Old Mar 30, 2010 | 05:35 PM
arcsum68's Avatar
Im no expert, but have done alot of reading lately.
Sounds like a kill/on off switch may be bad, im sure someone will chime in, but I would test any and all with a multimeter or eliminate them from the loop.
Old Mar 30, 2010 | 05:38 PM
jday53's Avatar
Default ds50 wont run
I have spark so its not a kill switch issue i am thinking compression
Old Mar 31, 2010 | 08:43 AM
LT80's Avatar
LT80 Expert
Comp is low..
Old Mar 31, 2010 | 02:52 PM
jday53's Avatar
I know but I just put a new cyl. piston and rings on it cant figure out why it is low it shouldnt be??????????????????????????????
Old Mar 31, 2010 | 05:40 PM
LT80's Avatar
LT80 Expert
Try a few drops of oil in the plug hole to tighten it up. Should pull fuel in now.
Try hand choking it (2 fingers in front of carb).
Old Mar 31, 2010 | 07:06 PM
jday53's Avatar
I am getting fuel and spark It wont fire even with starting fluid so choking it isnt going to help I think its just cause the comp is so low but I cant figure out why its so low???
Old Apr 1, 2010 | 12:09 AM
LT80's Avatar
LT80 Expert
I'll explain better putting oil in the spark plug hole will allow the piston wall clearance to tighten up This will increasecompression and hopefully pull fuel in Hand choking will help the fuel get in with less compression comp is low because the rings are not seated and won't be till run a bit
LMAO :-P
Old Apr 1, 2010 | 12:16 AM
jday53's Avatar
So you think putting a drop of oil in the cyl will gain compresion enough to fire? even though it wouldnt fire directly on startin fluid. as I stated before I am getting fuel into the cylinder?
Old Apr 1, 2010 | 09:54 AM
LT80's Avatar
LT80 Expert
You stated you have a problem.
I stated things to try....Start trying..LOL
And yes, I think a few drops of oil can make a difference.
