Oils,fluids,etc
Old Apr 21, 2010 | 02:20 PM
1in9twist's Avatar
Default Oils,fluids,etc
Greetings
Do you guys buy the factory Polaris gear,motor,etc oils? In my manual it says "change front diff fluid with Polaris # blablabla" But gives no specifications for cheaters like myself..........
Old Apr 21, 2010 | 02:42 PM
DODGE57HEMI's Avatar
Mopar Man!
I would unless you went with oilf from places like AMS oil or Redline!
Old Apr 21, 2010 | 02:43 PM
nc porider's Avatar
Default oils
the adc oil and demand drive should ONLY be polaris if you try anything else in that it will give you headaches, as far as the diff. fluid i use amsiol and amsoil in the engine also amsiol in the tranny
Old Apr 21, 2010 | 03:59 PM
switzomatic's Avatar
I use all popo fluids because it isn't much more expensive than the other stuff and it will help if you ever need warranty work done. Some dealers are sticklers on that stuff and will try to blame a problem on using non-popo fluids. Also helps to keep a good rapport with the dealer. That can go a long way on future purchases or issues!
Old Apr 21, 2010 | 04:57 PM
Pous's Avatar
I use Mobil 1 0w-40 in the engine of my 500, Type F automatic transmission fluid for the front hubs as it is the same as the polaris hub oil, a 50w synthetic in the transmission, and polaris oil for the front diff. and ive never had any problems
MaasaiMomma
Mar 25, 2021 11:24 AM
Shainasmash
May 8, 2017 06:38 PM
Technical and How-To Articles
Aug 21, 2015 09:31 AM
rjacree
1) Engine problems..
Aug 3, 2015 10:21 AM
rcappie4
Jul 10, 2015 04:54 PM
