cv boot replacement
Old Apr 23, 2010 | 11:39 AM
Crazyotto1's Avatar
Default cv boot replacement
I just replaced some cv boots on an arctic cat 500. When I did the replacement I was able to pull out the inner knuckle (closest to the differential) completely apart to replace the boots. The knuckle closest to the tire I couldn't figure out how to get that one apart. How does it come apart? Whats the trick? If the splines on the axle hub was bad, how would I get the knuckle apart to change the end? The cv joint closest to the wheel does not pull apart like the one closest to the differential did with the little C clip.
Thanks for your help.
Old Apr 23, 2010 | 12:01 PM
ChatterMan's Avatar
it does have a c clip,you just can't see it,what i do is put it in a vice so that the cv is on top then holding the axle under the vice use it as a slide hammer,and bang of the cv off,when you go to put the cv back on, you will have to use a little screw driver to help push the c clip,or start the c clip back down into the cv
Old Apr 23, 2010 | 05:17 PM
Crazyotto1's Avatar
Cool Thanks
toonces
Aug 6, 2015 10:46 AM
toonces
Aug 5, 2015 05:55 PM
toonces
Jul 28, 2015 01:58 PM
TLC
3) General Discussions..
8
Jul 26, 2015 11:09 AM
TLC
Jul 25, 2015 02:24 AM
