Phoenix 200 brakes
Old Apr 24, 2010 | 07:54 PM
twister500's Avatar
Default Phoenix 200 brakes
Has anyone replaced the rear shoes and how was it?
I just ordered a set of shoes for my sons 200 and just wanted to know if I have suprises to look foward to with pulling the drum or anything else. Thanks in advance.....Steve
Old Apr 24, 2010 | 08:05 PM
After you remove the rear drum cover the drum can be tapped off after you remove all tension on the brake cable. Sometimes if the drum cover seal leaks,the drum can be a little rusted and hard to get off. Just lightly pry on the inner drum lip as you tap on the drum,should come off. Be sure to really clean the inside of the drum as the new shoes can be a tight fit at times. OPT
Old Apr 26, 2010 | 07:55 AM
twister500's Avatar
opt thanks for the reply. I thought it was straight foward but just wanted to check. Thanks again.
Old Apr 29, 2010 | 05:11 PM
twister500's Avatar
Hey OPT thanks for the info I knocked it out in about 30 minutes. The screws for the drum cover were a PITA a$$ but I got them loose with vise grips. The drum was full of water and muck I found that the O-Ring is shot so I have a new one on order. Thanks again.
Joe454
Nov 20, 2020 01:19 PM
EIF
Apr 20, 2017 07:15 PM
Whitelx1
Oct 2, 2015 10:55 PM
oliveiracarlos
Sep 7, 2015 03:39 AM
oliveiracarlos
Sep 6, 2015 01:38 PM
