Headlights dimming
Old Apr 25, 2010 | 08:35 PM
monster malibu1's Avatar
Default Headlights dimming
The lights on my 99 Sportsman 500 go from bright to dim all the time and I don't know why. All lighting connections are clean and die-electric greased.
Anybody know what needs to be replaced?
Old Apr 25, 2010 | 09:07 PM
readymixer169's Avatar
Of all the things I've lost in life, I think I miss my mind the most!
Sounds like your battery is getting weak or your stator/or rectifier is going out(which I doubt). My money would be on the battery. How old is it?
Old Apr 26, 2010 | 03:00 AM
Battery is less than a year old and the light surging problem was there before the battery swap.
Old Apr 26, 2010 | 04:25 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
you need to check the voltage out as it might be your recifier going bad or having bad connections if you didn't clean that one.
Old Apr 27, 2010 | 08:35 PM
caperinmuskoka's Avatar
Ride like you own it, Not like it's stolen!
I think it might be just the cooling fan kicking in doing it's cycle.
The fan comming on will make the headlights dim a bit on my Sp 450's also................
All depends on how much dimming your talking about.........Just a flicker or down right loss of light..........Caper...
Old Apr 28, 2010 | 07:14 AM
My lights go from bright to dim while driving the bike, I might have bright lights for a few minutes then all of a sudden they go dim for awhile, this happens all the time while riding and it sucks.
Old Apr 28, 2010 | 07:39 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
did you check the voltage yet when they do thid to make sure it's still putting out correct amount?
Old Apr 28, 2010 | 08:18 AM
Haven't checked voltage yet and all connections are good, I was told it could be a bad rectifier.
Old Apr 28, 2010 | 08:33 AM
TLC's Avatar
TLC
The Rectifier is my guess, I rode my ATV with a dead battery for a month before getting a new one and the lights still worked normal.
Old Apr 29, 2010 | 03:33 AM
I just installed 3 HID lights on my bike and I'm going to findout if the surging continues with these new lights this morning (3:45 am) on my way to work.
