Front Bearing Torque
Old Apr 27, 2010 | 03:36 PM
JKW's Avatar
JKW
Default Front Bearing Torque
I found this in a search for front wheel bearing; 160-170 in/lbs back off a 1/2 turn retorque 108-144. It wasn't specific, I think, on the year Sportsman. It seems like a lot of preload to me, compaired to the old auto+truck wheel bearings. But, I've had repeated seal leaking problems.
2002 Sportsman 500
Thanks
GOT MUD!
Old Apr 27, 2010 | 06:28 PM
2002 Sportsman 500
Thanks
GOT MUD!
Yes final torque is 144" pounds on the 02 Sportsman 500. I always preload bearings to as it says about 160" pounds (15' pounds) and back off 1/2 turn and torque to 12' pounds (144" pounds). About leaking,is it at hub or strut seal leaking?,have they been replaced?If so the strut seal can be installed too far into the casting and will cause leaking,plus the hub seal has to be pressed in properly or it too will leak. OPT
Old Apr 27, 2010 | 08:51 PM
Outback31's Avatar
Has ridden Rockhouse and Bearwallow trails.
Default 07 800
OPT, off the top of your head can you tell me the torque specs for my 07 800. I think its 70 to 80 ft lbs but just want to be sure.
Thanks for your reply
Old Apr 28, 2010 | 08:57 AM
TLC's Avatar
TLC
JKW
Here is a excellent HOW TO DO front hub rebiult link for your ATV with pics.
ATV Time :: View topic - Polaris Demand Drive Hub Q&A Picture Guide to Service
Old Apr 28, 2010 | 05:39 PM
JKW's Avatar
JKW
old polaris tech and TLC
Thank You for the replys and information. Like everything, the more I learn about something, I realize how little knowedge I had at the start! We'll give'er a shot with it set up correctly!
Thanks Again!
Ean
Dec 19, 2022 08:48 AM
JackTheKing
Jul 14, 2015 09:09 PM
clsharky
Jul 13, 2015 02:07 PM
Unzzy66
Jul 11, 2015 10:01 PM
tporath
Jul 11, 2015 12:31 PM
