2008 sportsman 500 ho
Old Apr 28, 2010 | 05:11 PM
james_b's Avatar
Default 2008 sportsman 500 ho
Hey guys my name is james and i am new to this site. i was wandering if you would be able to give my some advice. i am working on a 2008 sportsman 500 ho, and i cant get any spark out of it. I know i cant test the cdi so i want to be sure about what it is before i start buying parts. thanks
Old Apr 28, 2010 | 09:14 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
welcome to the forum. are you sure it's not a bad switch either key or kill? did it just die
Old Apr 30, 2010 | 03:23 PM
james_b's Avatar
thanks. yah it just quit all of a sudden when i was driveing, I am pretty sure its not the key or kill cuz I got power when i turn the key, and it still turns over. but when i have the kill switch in the off position it will not crank over so i just asumed if it was a bad kill switch it wouldnt turn over at all. or do you think it still would.
Old Apr 30, 2010 | 07:51 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
no your kill switch works fine as it should not let the bike turn over when the switch is on. so it turns over but has no fire?
Old May 1, 2010 | 09:05 AM
james_b's Avatar
well i figured a few things out last night, i can start it with the recoil and everything works fine. So what i did after i figured out i could use the pull start was unhooked the + starter wire then fired it up, once it was running i turned the key as if i was trying to start it, and nothing happened. i thought it would kill the engine when i did that. so that would mean my ignition is still good right? where should i go from here?
thanks alot for the help
Old May 1, 2010 | 09:41 AM
TLC's Avatar
TLC
Does the motor turn over with the electric start? Mine would not start with with the electric start turning the motor but would start with the pull cord. Turned out mud and crap got into the recoil through the rope hole and the Pluse coil next to the flywheel just needed cleaning.
The rope handle does a poor job of keeping stuff out of the recoil.
Old May 1, 2010 | 07:23 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
check to see if the bike has spark while starting w/ key switch and also by cranking it by hand(must have if it started) and if it turns the starter over but does not have any fire, check what he mentioned for issues. imo
Old May 2, 2010 | 10:14 AM
james_b's Avatar
yah the key will turn it over just fine, but wont have any spark. pulling the recoil it starts great, so i will take the recoil apart and see if its dirty.
thank guys
Old May 2, 2010 | 10:18 AM
TLC's Avatar
TLC
If it starts by pulling the rope, thats good news, it means the expensive stuff is still working such as the Stator and CDI.
If your rope looks wet and dirty,chances are you had lots of crap getting in there.
Old May 2, 2010 | 05:44 PM
james_b's Avatar
i goter all fixed, it didnt look all that dirty but i cleaned up the flywheel and moved that little pickup coil a little closer to the flywheel becase it looked like it was bent out.
thanks alot i never would have thought to do that.
bzdok1234
30
Feb 23, 2016 01:55 PM
panicmanic
Aug 25, 2015 09:10 AM
velcro7279
Aug 24, 2015 01:15 PM
Donniereble
Aug 21, 2015 10:46 AM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
