Can't Pull Past TDC
Old Apr 29, 2010 | 11:42 AM
eni9ma's Avatar
Default Can't Pull Past TDC
I have a 99 Polaris Sportsman 500 that I recently replaced the piston and rings on (Wisco oversized). After the replacement it's extremely hard to start. When pull starting it's physically difficult to get the piston to turn over. Have to tug/bounce on pull cord to get piston to turn over. If the spark plug is removed I can pull it over without issue. I have other symptoms that I believe are related to this root cause - such as it bogging out at 1/3 throttle, sensitive carb idle (once warmed up will kill - if idle adjusted won't start). And the plug is new and you can see an image attached.
Any know what I can look for? Seems like there is too much compression or the timing is off - even thought the TDC marks were used for piston installation according to the Service Manual.
Thanks
Old Apr 29, 2010 | 12:39 PM
Check the cam exhaust detent spring and arm on the left side of the cam. If its set wrong or spring not correctly in place will cause hard starting,rich condition and and bogging down.
Old Apr 29, 2010 | 12:47 PM
eni9ma's Avatar
old polaris tech -
Thanks for the reply, greatly appreciate. I'm looking up the "cam exhaust detent spring and arm" in the service manual now and will review.
Would these symptoms still exist when the spark plug is removed if it is due to the "cam exhaust detent spring?"
Old Apr 29, 2010 | 12:57 PM
eni9ma's Avatar
This is the spring you're referring to... interesting. I can understand how this could have not been reinstalled correctly. I would have never looked there.
Old Apr 29, 2010 | 03:22 PM
The spring could get out of place which its purpose is to bring the detent lever back against the stop after the engine cranks. This could have something to do with hard engine turnover and even recoil hard to pull..I KNOW,I've done this and experienced some of the symptoms you are having,hard start/recoil problem and wont throttle up.This may or not be your problem,but check that detent spring is wound properly and lever flips back with your finger. With the spark plug out it would be easier to turn over. Just a thought?? OPT
Cummins Driver
Sep 11, 2019 01:22 PM
SDR-II
Sep 29, 2015 01:06 AM
MikeyBoyesq
Aug 10, 2015 11:11 AM
Lpshann
Sport Quads
Jul 29, 2015 08:11 AM
