Outlaw 525 sputtering at high RPM
Old May 2, 2010 | 03:20 PM
iRideGSXR1000's Avatar
Default Outlaw 525 sputtering at high RPM
Just bought this bike used for a steal, and found out it sputters when you get get to the top of each gear. It sputters, backfires, and loses power until you shift into the next gear.
It has a full muzzys exhaust on it, no aftermarket filter, but I just installed a stage 2 jet kit in it. Turned the mixture screw out 2 turns... and it still does it. The problem got a tad bit better tho. The only mod to the carb before that was it had a 146 jet, and now its down to a 142 (what the manual told me for a stage 2 at my altitude.)
So before I pay money to get it fixed, anyone have any suggestions on what the problem could be?
Old May 2, 2010 | 09:32 PM
zero9quads's Avatar
Have you cleaned the carb thouroughly? Sounds like the main jet possibly did you spray out the main jet port when you replaced it?
Old May 3, 2010 | 07:31 AM
no i did not clean anything... I guess that could be my next step, but I dont see how you'd have to clean a brand new jet and the adapter that goes in first?
Old May 3, 2010 | 09:59 AM
Kerbbirds's Avatar
boggin and backfire at hi rpm tells me its lean, go back up in jet size and see what it does.
Old May 3, 2010 | 10:28 AM
Ok so I took out the plug and it is pretty white. Has a slight yellow tint to it. So should I jeep screwing with te mixture screw or leave it at 2 turns out (what dynojet recommends) and keeping upping the jet. Or play with mixture screw with every upped jet?
Old May 3, 2010 | 04:18 PM
Kerbbirds's Avatar
2 to2.5 on the mixture will be fine , if plug is white I would go back to the 146 jet, these run better on the little black side
Old May 3, 2010 | 08:50 PM
i put int he 146 jet and removed the airbox lid. Seems to be running fine... Has a few little spits every here and there... Im going to quit screwing with it until I get the quiet core for it. I do know for sure it was the jets tho, so the only problems I can have from there are going higher or lower on the jet.
ReconBayou
Oct 31, 2022 05:37 PM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
BYC
Sep 25, 2015 02:10 PM
Bernhard
Sep 25, 2015 12:45 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
