3 headlight mod kit
Old May 2, 2010 | 09:03 PM
monster malibu1's Avatar
Default 3 headlight mod kit
I bought a 3 headlight mod kit from Quad-o-vator for my 99 Sportsman 500 and now my lights flash like strobe lights, anybody know why this is happening?
Can't I just remove the 3 light mod diode and replace it with a jumper wire?
Old May 3, 2010 | 08:44 AM
readymixer169's Avatar
Of all the things I've lost in life, I think I miss my mind the most!
Sounds to me like if you have it wired correctly the diode might be bad. I'd contact them and let them know what it's doing. For no more than they cost they might just send you another one free of charge. I would'nt just use a jumper, the diode's in there for a reason.
Old May 3, 2010 | 05:23 PM
Greg at quad-o-vator said my HID light combination needs to much power at start up for the diode, so he said I'll need to swap the diode with a relay.
Old May 3, 2010 | 07:17 PM
Anybody here running Burke moto-pros lights along with a Quad-o-vator 3 light mod kit?
Old May 3, 2010 | 10:17 PM
chuck_raduenz's Avatar
sounds strange. a jumper wire will make all your lights work reguardless if the switch is in high or low beam. dose it work like its supose to? low is just low beam and high has all 3 lights on? what flashes, high beam, low beam, all 3?
if anything change it to a relay.
Old May 4, 2010 | 03:21 AM
All 3 flash when I turned my high beams on and they shouldn't.
Old May 4, 2010 | 04:09 AM
wow. im confused... take the diode off and see if just the high beam flashes.... or try a differnt diode. or use a relay.
Old May 4, 2010 | 04:04 PM
Going to switch the diode out for a relay.
Whitelx1
Oct 2, 2015 10:55 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
PrairieDog126
Sep 16, 2015 01:33 PM
