K&N or UNI?
Old Mar 2, 2001 | 12:48 AM
shakeyjake69's Avatar
Does anyone know which of the two air filters allows for better performance? Please help!
Old Mar 2, 2001 | 07:26 AM
OneDollar's Avatar
You'll get better performance from either one over stock. The decision should be made by what type of riding. Uni will filter fines better than K&N. So if you ride in areas where there is alot of fine dry dusty particles go with the Uni.
Old Mar 2, 2001 | 12:17 PM
AKScrambler's Avatar
As good as I believe K&N to be, I would agree that UniFilter is the way to go with ATVs. I run Uni's in both my Polari.
Old Mar 2, 2001 | 12:28 PM
waynaferd's Avatar
The K&N allows better airflow, but the UNI filters smaller particles, but either will outflow the stock filter.
Old Mar 2, 2001 | 06:38 PM
DieselPro's Avatar
Hey, you guys are smarter than some of the diesel guys I have to deal with!
Just spoke to a guy with 10k on a rebuild, and his chromium levels doubled on his oil analysis. So did SILICON! What air filter? Just put in a spanky new K&N a few hundred miles ago!
Simply put, more top cylinder wear from dirt getting through K&N filter!
Old Mar 3, 2001 | 01:40 AM
pudljumpr's Avatar
I have a K&N and it gave me about 3mph on the top end. If you have prefilters for your system, it's a great filter. If not it still is a great filter. It will last forever because you can clean and reoil it. But if you're not running a prefilter, check it frequently to make sure oil is still catching the dirt.
'98 Xplorer 400; K&N
Old Mar 4, 2001 | 03:07 AM
max400ex's Avatar
uni = protection
k&n = performance
Old Mar 4, 2001 | 12:07 PM
DieselPro's Avatar
On another note, I have something to point out about K&N.
> > Today at a Dodge
> > ralley at a dealership, they informed us the if they
> > loose an engine now,
> > they are required to confiscate the air filter. They have
> > found sand blasted
> > engines and lost soo many to K&Ns, that they now want to
> > cut their losses.
> > They said point blank, if a K&N is in there, your
> > probably going into a
> > fight for warrantee if the engine needs replacing.
> > The reason? K&N cannot stop the dirt in a turbo charged
> > engine. The more the
> > engine is bombed the air flow increases exponentially.
> > So, yes, the K&N has proved great air flow, but at what
> > cost?
