Please help 99 Polaris Xplorer ATV
Old May 4, 2010 | 06:05 PM
hwc's Avatar
hwc
Question Please help 99 Polaris Xplorer ATV
We have cleaned the carbs, but still not getting gas to the spark plug. Anyone have any suggestions on what else we can check.
Thanks
HWC
Old May 4, 2010 | 06:24 PM
You can pull the gas line from the carb and try to crank engine,if fuel is flowing from the fuel line you may have some other problem. If not, check/replace fuel filter,check that vacuum line from fuel pump to carb is secure and not loosing vacuum. Fuel pump diaphrams can wear out but not that often. Hope this is somewhere you can start to check.. OPT
Old May 4, 2010 | 06:53 PM
hwc's Avatar
hwc
installed new inline fuel filter,,gas is gettin to the carb,,,hav good spark,,still wont start
Old May 4, 2010 | 11:19 PM
mrtwostroke's Avatar
check for compression.
Old May 5, 2010 | 06:01 AM
ftwflh's Avatar
ditto
Ramman1
Aug 11, 2022 01:53 PM
NoJoke
Aug 9, 2015 12:39 PM
Polaris Side by Sides
Jul 30, 2015 12:14 PM
cornermike
Jul 30, 2015 06:37 AM
cornermike
Jul 8, 2015 11:44 PM
