Please help 99 Polaris Xplorer ATV
You can pull the gas line from the carb and try to crank engine,if fuel is flowing from the fuel line you may have some other problem. If not, check/replace fuel filter,check that vacuum line from fuel pump to carb is secure and not loosing vacuum. Fuel pump diaphrams can wear out but not that often. Hope this is somewhere you can start to check.. OPT
