Flashing wrench on dash
Old May 4, 2010 | 07:36 PM
dwyer83177's Avatar
Default Flashing wrench on dash
Does anyone know what a flashing wrench on the dash means. I do not have the owners manual for my 04 sportsman 600, or a repair manual yet.
Old May 4, 2010 | 08:18 PM
Tundra27's Avatar
Means nothing. I believe you can set the number of hours till your next tuneup. Sort of like a timer...
Old May 4, 2010 | 08:50 PM
hallj86's Avatar
or your their is something else wrong its not just a service indicator
Old May 4, 2010 | 08:54 PM
Kerbbirds's Avatar
If it just flashes when you first strart it and quits after a few seconds it is the service indicater, if it stays on there is a code and something else is wrong.
Old May 4, 2010 | 09:25 PM
dwyer83177's Avatar
ok good, it only flashes on start up, anyone know how to read the codes or reset it
Old May 4, 2010 | 09:58 PM
chuck_raduenz's Avatar
im not shure on the older ones. but if i rember on my 08 it has to be in neutral. turn the key off wait 10 sec.
set the parking brake. and shift into neutral
hold reverse over ride button as you turn on the key switch to on
release the override switch as soon as the display is active.
then scroll thought the menu with the yellow override button.
Old May 4, 2010 | 10:03 PM
Kerbbirds's Avatar
to check the codes put it in neutral set the brake and cycle the key on and off 3 times if i remember right
Old May 5, 2010 | 07:47 AM
Spdecat's Avatar
It being a 04 and not EFI will it even show a code ? My 08 show's no codes as it's not a EFI .
Old May 5, 2010 | 10:06 AM
Kerbbirds's Avatar
good point i didn't even notice what bike it was you shouldn't have any codes because there are no sensors on the bike. i need someone to slap me in the back of the head sometimes
Old May 5, 2010 | 12:28 PM
uncle matt's Avatar
The flashing wrench means that you are a winner in the Great Polaris Tool Giveaway!
Take your machine to your dealer and show them the flashing wrench. They will reset your machines computer to make the flashing wrench go away and you can select your prize from a list of awesome Polaris service tools!
Congratulations!
