Eton 50cc won't start when carb adjusted
Whenever I warm up my Eton Viper 50cc and adjust the carb for optimal running it won't start up the next day.
The manual says that the air/fuel mixture screw should be 3/4-1 1/4 turns out from bottom, but the ATV runs WAY too rich when it is at that point. When I adjust it I find that 2 1/2 to 3 turns runs great, so I set it to 2 turns for a richer mixture for cooler running. The problem is that I cannot start the quad after it cools down. It doesn't matter if the choke is off or on, I cannot get the thing to kick over. It just cranks and cranks with no sign of life. I have to turn the air/fuel mixture down to 1 1/4 turns to get it to start.
What could be the problem?
Thanks for your help.
loquist
loquist
I dont know about your carb, but the Mikuni on my 200CC Gio quad, as you turn the screw out, it gets richer, unless yours is an air metering jet, not a fuel metering jet.
Have you tried pulling the plug when it doesnt start? I wonder if it is getting too much fuel with the idle screw out that far?
armpump450r
Technical and How-To Articles
Apr 1, 2017 06:11 AM
