Lower (Big End) Connecting Rod Bearing
Old May 6, 2010 | 07:41 AM
twin80's's Avatar
Default Lower (Big End) Connecting Rod Bearing
I'm doing a basic top end rebuild on an Xplorer 400 (2 stroke). I bought it "not running" and knowing it needed a new top end. As I removed the header pipe from the head it had sitting water in it. After removing the piston I noticed the ower connecting rod doesn't move too freely, it's not siezed up. Seems like the needle bearing may have a little rust due to some moisture and sitting for some time.
There is although no play as in side to side motion so it shows no sign of your typical bad bearing senerio.
Should I give it some type of lube to help free it up and continue with the rebuild or is the something that is gonna to require splitting the bottom end?...which I have never done.
Old May 6, 2010 | 07:50 AM
Speeddrive1's Avatar
If there is any binding at all in the bearings they need to be replaced. I would also replace the crank bearings and seals at the same time.
Ean
Dec 19, 2022 08:48 AM
Divergent12
Dec 30, 2017 08:33 PM
toonces
Aug 5, 2015 05:55 PM
ManuelCarrillo3
Where to Ride
Jul 27, 2015 07:53 PM
musselmark
Jul 17, 2015 02:40 PM
