1999 AC 300 Popping
Old May 6, 2010 | 04:54 PM
katiebee's Avatar
Default 1999 AC 300 Popping
We have a 1999 AC 300 4x4... it's recently starting "popping" when I'm driving it.
It jerks the front end just a bit and makes a loud "knock", almost like it's shifting hard except that I'm not shifting when its happening... i'm just driving straight.
We took it to the shop and they can't find anything wrong... said the bushings on the shocks need replacing but that's it.
Any ideas?
Thanks,
Kate
Old May 18, 2010 | 11:48 PM
Williebee's Avatar
Post 1999 AC 300 Popping
Any ideas?
Thanks,
Kate
Welcome to the forums katiebee !
Sound's like front CV joint's are most likly the problem .
williebee.......
Old May 20, 2010 | 11:21 AM
swampyjunior's Avatar
I agree you should look at your CV joints on the front as well as the wheel bearings, ball joints, tie rod ends, shock bushings, 4x4 not engaged all the way in or out, and front differential.
Try jacking the front of the ATV up so both front tires are off the ground. Then place one hand at twelve-O clock and the other at 6 and see if the tire wiggles or makes a noise while you move it. You should have little or No play in the tire at eh hub (wheel bearings). If you lift the A-arm up and down and hear the noise look to see if it from the shock bushings OR the ball joints.
I know the shock bushings seem to wear our fairly fast due tothe weight of the machine. This can make a clunking sound when you go over bumps. They are fairly cheap (like $3 or so).
Hope this helps
Swampy
Also try moving teh axle shaft around, turning the tire etc. See if you can get it to make the sound and pin point its location.
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
Alex G.
Sep 11, 2017 11:38 PM
Scooter's Shop
23
Oct 22, 2015 07:04 PM
Dunes and Dune Machines
Sep 29, 2015 09:35 AM
r1pilot83
Sep 27, 2015 07:38 PM
