sportsman tips or tricks?
Old May 8, 2010 | 04:19 PM
tph99's Avatar
Default sportsman tips or tricks?
my dad just bought an '06 sportsman 500 EFI, and i bought his '04 400. does anyone know any tips or tricks for either one? just curious if there is any simple things to know about them.
thanks
Old May 8, 2010 | 05:24 PM
hallj86's Avatar
change the hub/ diff fluid consistantly
Old May 8, 2010 | 06:10 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
do service and keep it maintained and they should do fine.
Old May 8, 2010 | 09:14 PM
TLC's Avatar
TLC
No hub fluid on a 06. The best thing is silicon your pull rope handle down. I can guarantee you water and mud will work its way down at some point and cause havoc on your $300 stator,Bendix drive,pulse coil.
ONLY USE 0W-40 oil also.
Old May 8, 2010 | 10:32 PM
tph99's Avatar
ok
Old May 20, 2010 | 10:06 PM
tph99's Avatar
nothing else?
Old May 21, 2010 | 08:43 AM
They're heavy machines. Don't get lazy in the corners or going up and down hills. If you don't use body English they can jump up and bite you.
Old May 21, 2010 | 03:35 PM
sportszillasheex's Avatar
is the 0-40 a fact? can others chime in on that
Old May 21, 2010 | 09:45 PM
jethrob's Avatar
I'm gonna silicon my pull rope, thanks for the tip on that.
Hey I've got a tip for you. You know that pesky reverse override/4wd bypass button?
Get a couple of zip ties and fit it losely around it. The buttons tension helps keep it in place, but you can slip it up to toggle your functions if needed.
It's the best mod on my bike, cost 15 cents.
Old May 22, 2010 | 08:46 AM
Spdecat's Avatar
Use 0W40 or Polaris PS4 plus which is 2w50 myself I use Amsoil 0W40 with Amsoil filters .
