99 250 oil drain?
Old May 9, 2010 | 07:25 PM
hoot619's Avatar
Default 99 250 oil drain?
There are 2 plugs one is a 14mm and the other a 17mm on the bottom of the case.. . Which is the oil drain? the 17mm one has 3 small bolts holding it up. Like a small lid. I can't remember which one it is. I have the filter and oil . My darn memory is no good any more. Ken
Old May 9, 2010 | 09:09 PM
mudslinginfool's Avatar
Does it in the Mud!
its the 17mm. the 3 little nuts are there to remove the screen type filter thats in there.
Old May 9, 2010 | 10:06 PM
hoot619's Avatar
thanks Mudslingingfool.
I have changed the oil and filter before but I know I haven't removed the screen. You can tell I am not much of a mechenic, hell I can't even spell it. But will do it tomorrow. Will also write it down in my owners manual so i don't forget. Thanks again , Ken
Old May 18, 2010 | 08:36 AM
arctic500202's Avatar
I believe you need to drain the oil from both plugs. Same oil in both but the way it is put together you cannot drain all the oil from one. That is the way the 300's are. Same basic motor.
ReconBayou
Oct 31, 2022 05:37 PM
Alex G.
Sep 11, 2017 11:38 PM
wrencher82
Sep 30, 2015 04:27 AM
wrencher82
Sep 28, 2015 10:02 PM
wrencher82
Sep 24, 2015 03:39 PM
