2007 650 h1 no engine braking
Old May 13, 2010 | 12:42 AM
ishootbear's Avatar
Default 2007 650 h1 no engine braking
Can someone help me out here.i recently bought a 2007 650 h1 and it has no engine braking just keeps rolling on flat or going down hill.any ideas?
Thanks Bryce
ishootbear@gotsky.com
Old May 13, 2010 | 03:34 PM
cupsz71's Avatar
Cool
2 things:
could be a REALLY loose belt....or the 1-way bearing inside your clutch housing is bad. Either way you have to pull off the side cover then depending on which one it is, you remove the external clutches/belt then you have to pull off the wet clutch housing to get inside the motor.
I'm thinking it's probably the bearing, cause IF it was the belt I'm pretty sure you'd FEEL the slipping when riding under throttle.
Good luck.
.02¢
Old May 13, 2010 | 06:48 PM
ishootbear's Avatar
Thanks
Sjrpp
May 2, 2023 03:59 PM
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
timster911
Jul 13, 2015 01:57 PM
Sjrpp
Jul 5, 2015 09:04 PM
