LT80 Melted clutch, bad crank
Old May 25, 2010 | 06:05 PM
zebradog's Avatar
Default LT80 Melted clutch, bad crank
Well, I got my daughter's bike together and it turns out I forgot the thrust washer for the front clutch. It bored a hole in the fixed face plate, ground the splines down on the crank shaft, broke the key in the crank shaft, gouged the starter gear, and melted all the rollers in the front clutch. *sigh
I'm going to take the thing back apart and replace just about everything in the front half of the motor, except the piston and rings which only had about 30 minutes on them. Does anyone know where I can get a cranks from? Are they just the OEM cranks that are out there or are there aftermarket ones? Does anyone know where I can get a good price on one? I'm going to replace the whole thing, bearings, seals...everything.
Any help is appreciated.
Old May 26, 2010 | 08:04 AM
LT80's Avatar
LT80 Expert
I have a good used crank here.
Old May 26, 2010 | 10:33 AM
zebradog's Avatar
I'll give you a call, thanks.
robert301972robert
Aug 30, 2015 11:34 AM
Bergmann
Aug 13, 2015 03:51 PM
Hatrackr
1) Engine problems..
Aug 11, 2015 09:03 PM
clsharky
Jul 13, 2015 02:07 PM
Wnthunting
Jul 9, 2015 03:02 PM
