apache 100 rlx wont start
Old May 27, 2010 | 08:32 AM
damo t's Avatar
Default apache 100 rlx wont start
hi im new 2 this and quads i bort a quad last week non runner for cheap very cheap and i carnt get the fing started its got a good spark and good fuel flowing thro it just wont turn over eny ideas plz help plz thanks
Old May 29, 2010 | 04:32 PM
damo t's Avatar
plz some 1 give me somthing i need this running its summer i want 2 play
Old May 30, 2010 | 07:32 AM
LT80's Avatar
LT80 Expert
id du a cumpresson tust
Old May 30, 2010 | 01:35 PM
damo t's Avatar
its got plenty ov compression its got spark and fuel i just carnt fink at all im fukd off with it
Old May 30, 2010 | 02:19 PM
damo t's Avatar
ist getin fuel 2 the carb but the spark plug is dry any ideas plz
Old May 30, 2010 | 02:41 PM
LT80's Avatar
LT80 Expert
I got some Ideas....
1) clean the carb making sure the jets are open and fuel is flowing thru the float needle seat.
2) try putting 2 fingers in front of the carb to hand choke it.
3) make sure the pipe isn't plugged
4) learn how to comunicate intellegently. Things like "F*kd" won't fly long in these forums.
Old May 31, 2010 | 04:31 AM
damo t's Avatar
ok and ive had a look at carb i think its ok but thers a pipe wot goes to oil pump i dont think its getin fuel down there i just dnt no wot to do do u think takin pump off and clean that will help m8
Old Jun 2, 2010 | 09:17 AM
damo t's Avatar
hi im back again i cleaned carb and cleaned oil pump but now im not getin a spark but i checked most ov the wires with 1 ov them electric screwdrivers and only a fewwas flashin wot could it be im baffled now plz help
Old Jun 3, 2010 | 09:44 AM
damo t's Avatar
hi again i realy need help plz post something bk apache rlx 100 wont start i did have a spark but now i dont after cleanin oil pump out and i tested all the wires with 1 ov them screwdrivers what lights up and only a few was lighting does eny body no a solution or eny idieas thanks
Old Jun 4, 2010 | 10:01 AM
stuartshomepc's Avatar
Well, if you had spark and then unplugged a bunch of wires to test them and now you don't have spark I would suspect that one of them is not plugged in all the way, or a terminal bent in the connector. Double check all of that.
And, slow down and use some grammar and spell check to your posts. They read like it's a 6 year old typing them. People will be more interested in helping if you have a clear posting.
MikeyBoyesq
Nov 27, 2020 02:44 PM
Mkp
Mar 28, 2020 03:50 AM
tiresharkdbb
Sep 3, 2017 02:06 AM
garyt1975
Jun 5, 2015 08:53 AM
1000gade
May 27, 2015 12:37 PM
